After i drive the car for a lil bit about 45 min then ill shut it off to go shopping for somthing. when i come back it cranks over but wont fire up. so i give it another hour be for i try to start it again. and i starts right up?? i have had a new crank case sensor put in and had the codes pop up only once for a cam shaft positioning sensor, now that code doesnt come up. i did not replace the cam shaft positioning sensor. Any help would help i have been to four places and they cant figure out the problem.
Jun 27, 2013 at 3:27 AM
