bogging down
100,000 MILES
JANET26
  • 6 POSTS
Could it be the throttle body sensor? It's bogging down on the highway then goes back up. I've change the injectors still doing it new fuel pump, new gaskets don't know what else to try.
Thank you
May 24, 2013 at 4:45 AM
RACEFAN966
  • 5,029 POSTS
Have you checked the timing control module? This is not the ignition control module it is a square box either mounted behind the distributor or on a bracket near the air cleaner. Let me know if you need help checking it and I will walk you through it.
Jun 29, 2013 at 12:06 AM
