Truck bed swap?
260,000 MILES • 6.6L • V8 • 4WD • AUTOMATIC
TAMULL66
I’m brand new here so please forgive any missteps. I was reading about Tim and his swap. The document detailing sizes etc. was great. Is there similar info regarding the 2020-2024 bed ?
I’m trying to see if I can put this on my 2004 2500 hd turbo diesel Chevy Silverado.
Feb 26, 2026 at 5:24 AM
STEVE W.
  • 15,381 POSTS
In theory you can swap any GM bed for any other as long as you use the same bed length. However it's not quite as easy as it sounds because the newer beds use modules for the lights and you need to work out the wiring and controls to make them work. There is also a question of appearance as in most cases the body lines are very different. The frames are different as well and in many cases the bolt holes don't line up. For that you end up making spacers and such to make things fit. This thread might help -
https://www.silveradosierra.com/threads/bed-swapping.760517/
Feb 26, 2026 at 11:45 AM
TAMULL66
Hey thank you for that info.
I’ll check it out and determine my next course of action
Feb 26, 2026 at 1:08 PM
STEVE W.
  • 15,381 POSTS
You are welcome.
Feb 26, 2026 at 4:20 PM
