Rough idling and hot or burnt smell of coolant
2004 FORD EXPLORER
140,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
BRUCEWC
The truck idles rough and gives off a hot or burnt smell of coolant. It did overheat and leak maybe a half cup of coolant out of the reservoir but has not done it again in about two to three months.
Feb 14, 2018 at 6:20 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If there is white smoke coming out the tailpipe then the rough idle and the burning coolant smell could be because of a blown head gasket, but I think rather you are smelling the burning coolant from under the hood. If that is the case than perhaps you have a coolant leak and it is leaking onto perhaps a ignition component and causing the misfire, perhaps leaking on a spark plug wire.
Feb 14, 2018 at 9:41 AM
