Cranks but does not start
25,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
RSDGGI
Can i clean a fuel injector up sk the truck will start? Also the truck will not start it turns over but wont start. i replaced the 2 coil pack and the plugs and it still wont start. any suggestions would be appreciated.
Feb 7, 2021 at 9:32 AM
  • 110,248 POSTS
If it won't start, chances are either it isn't getting spark to the plugs or fuel to the engine. Do me a favor. See if it starts for a couple of seconds using starting fluid. If it does, then we know it's fuel related. Also, here are two links. One explains how to check fuel pressure and the other ignition spark.
Take care and God Bless,
Feb 8, 2021 at 9:02 AM
