Transmission has a bad shift from third to fourth gear
200,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
RAMóN EDGARDO SARMIENTO MATUTE
The problem with the car is that the there is a bad shift from 3th to 4th. The change is delayed and, also when the first speed changes to the second one it works but not smoothly. One mechanic told me that the solenoid sensor in bad, but other mechanic made a test to the solenoid and it was okay.
I will change the transmission oil to see if this action will fix the trouble.
My question is: It is necessary to change the filter also, knowing that the filter is located inside the system? What are you recommendations?
Mar 31, 2021 at 2:57 PM
Good morning,
Changing the fluid is a good idea. There could be dirt or debris not allowing the valves to work properly.
As far as the filter, no, the transmission has to be remove and the case split apart to access the filter.
Mar 31, 2021 at 10:33 PM
Thanks for the information , its very helpful. I decided to change the oil, the car is working better , the shifts are better also. But I decided not to change the fiter. Regards,
Apr 7, 2021 at 3:59 PM
That was not a good idea. If there is dirt or debris in the filter, it can travel to the valve body and bring back the issue.
Apr 7, 2021 at 8:08 PM
I have to change the filter, the D4 is flashing again. It is possible that I will repair the system?
Apr 8, 2021 at 4:46 PM
It is possible but if you get me the code, I can narrow the area of failure for you. A parts store will read it for free for you.
Apr 8, 2021 at 7:44 PM
Thanks, I will go to the mechanic to see what the code is. I will tell you later. Regards
Apr 9, 2021 at 3:15 AM
You are welcome.
Always glad to help.
Apr 9, 2021 at 5:09 AM
