trouble to repair a speedometer
90,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
OCTAVIO 867
In my job I use a 1999 dodge ram V8 5.4 Laramie Automatic Transmission, but the speedometer has never worked, this make me stopped by officers saying that my speed is a little bit high, I am trying to repair the speedometer, I have checked all from the speed sensor to the ECU, and Check the signals with a Leader Oscilloscope, then, I see that the speed sensor signals are entering to the ECU but nothing is sent to the cluster, may somebody help me to know where may I find the signals that goes out from the ECU and are sent to the cluster, may somebody help me
Mar 21, 2016 at 9:51 PM
HMAC300
  • 48,601 POSTS
vss goes out from anti lock not ecm see pic but this may be a can bus problem and another module is giving the problem. if you have a pro style scanner use that to check the can bus.see pics for connections.
Mar 22, 2016 at 6:24 AM
