I have been having trouble getting my truck to start for a good long while. It used to be just in the winter and I would have to use starting fluid to start it. But now it is all the time. But usually I always get it running by using starting fluid or if that does not work let it sit for about fifteen minutes and then it would start. But one day when I was camping i had parked the truck with the front pointing down a slope and it would not start no matter what I did. So I had a guy pull my truck up out of the slip so I could get my camper out with another truck . As soon as I got on flat ground it started right up. Come to find out if I pull the vacuum line off of the throttle body the one that has some kind of filter on it the truck starts fine but will not stay running unless I use a remote starter so I can hook the line back on so it stays running. The thing is I cannot find anything on what this line is called so I can order a new filter for it or why this is keeping it from starting.
Mar 13, 2018 at 9:37 AM
