Trouble shooting brakes not working
1,800 MILES • 5.2L • V8 • 4WD • AUTOMATIC
BRIAN DENNY
  • 7 POSTS
Changed master cylinder, booster, proportion valve, brakes lines bled, still no brakes.
Nov 7, 2018 at 1:59 PM
Good morning.
It sounds like you have air in the system and that can be tough to get out.
Sometimes you need a power bleeder to force the air out of the system. You can rent one from a parts store. It actually forces fluid through the system to push the air out instead of using the foot pedal to try to bleed it out.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Nov 7, 2018 at 6:25 PM
