in the morning a little chugging until the engine warms up then it runs fine
210,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
JACK MCMAHON
My truck is Lv6 with 210,000 miles on it. sometimes will start rough or not start at all until I clear the fuel rail, it only happens when I shut it off and try to restart it. shortly after replaced injectors it starts no problem. in the morning a little chugging until the engine warms up then it runs fine, but I have also noticed it does not like steep hills. I have replaced the fuel pump and filter. i am thinking it might be an engine sensor or clogged catalytic converters and bad o2s. any ideas would be great.
Oct 7, 2016 at 12:38 PM
  • 55,694 POSTS
I'm wondering if the mass air flow sensor can be dirty causing a logic imbalance. Here is a guide to show you how to clean it.
https://www.2carpros.com/articles/mass-air-flow-service
Also a vacuum leak can cause this kind of problem as well.
Please let us know what you find so it will help others.
Best, Ken
Apr 21, 2021 at 4:06 AM
JACK MCMAHON
it was a bad MAF sensor all good now thank you so much!
