Trouble codes MAF / O2 1st bank?
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANDREWCHI
Problem: 2008 Toyota Camry LE
Failure Code P0171
I changed MAF sensor and the 02 sensor
New DENSO 234-9049 02 sensor and DENSO MAF 197-6110 sensor
Checked for vacuum leaks
Now that the two sensors are changed out I have a new code P2237.
I drive the car about 30 miles the check engine light is off. When I turn off the engine and then start the car again after 5 minutes the check engine light comes on with this new code P2237 .
I tried two more times clearing the code and re starting it after a drive. I get the same results each time.
If I put the old DENSO 234-9049 02 sensor back I get the check engine light and P0171 code again and the system sets up with 6 registers ready.
If I put the new DENSO 234-9049 02 sensor in again I get the check engine light P2237 code
with 3 registers ready.
I have checked the fuses and the relays they are all good.
Where do I go from here?
Oct 9, 2024 at 3:03 PM
  • 55,616 POSTS
It sounds like the new oxygen sensor is the wrong one or is defective. I would get another one.
P0171 - System Too Lean (Bank 1)
P2237 - Oxygen (A/F) Sensor Pumping Current Circuit/Open (Bank 1, Sensor 1)
Can I ask if the engine has an exhaust leak? This will cause a lean code. Here is a guide to help you check for vacuum leaks, test with the engine cold only.
Please go over this guide as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 10, 2024 at 5:53 AM
