I have two ECM codes present on scan tool p0153 o2 sensor bank 2 sensor 1 and lean code bank 2 p0174 . p0153 on scan tool shows confirmed. Scan tool shows unconfirmed for p0174 after changing DPFE sensor and mil light turned off.have checked for vacuum leaks and exhaust leaks with no leaks present. I'm not convinced the o2 sensor is the cause as fuel trims and voltage specs look normal within range.but at idle in park the vehicle acts like its enriching raising idle and the almost turning off the motor but then recovers to a normal idle. Fuel pressure look good but I'm not sure it the fuel rail damper is operation correctly. What would you advise for further diagnosis and trouble shooting to resolve the lean issue and idle problem. Outside these issues the vehicle runs descent. Thanks in advance for your expertise and help with this matter.
Jul 20, 2020 at 7:59 PM
