Trouble codes 81, 82, 83 after truck shut off
78,000 MILES • 6.5L • V8 • TURBO • 4WD • AUTOMATIC
CHLOE MATTHEWS
After driving my K2500 for about 30 minutes without a problem, it randomly shut off as if someone pulled the keys from the ignition. I lost power steering, dash warning lights (I can barely see my glow plugs light when I turn the key), and engine power. And now the truck won’t turn over; it will crank I can hear the lift pump and can hear the computer purring and dash warning lights don’t work, and it has codes 81,82, 83. Pointing me to the 1-2 solenoid, 2-3 solenoid and the TCC.
Could this be an issue with my ECM/computer? I don’t think it’s a mechanical or fuel delivery issue since I can get the truck to crank but I’m losing something, and she won’t turn over.
Please help. Many thanks.
Mar 22, 2022 at 11:01 AM
Diesel trucks rely on fuel pressure to start and run so we need to check the fuel flow and pressure.
I am attaching the testing below that we need to run through.
Here is a guide that will help others but your truck being a diesel is slightly different:
The codes are most likely as a result of the engine shutting off and not the cause so the fact that it will turn over but not start points us to a fuel issue.
So, let's start with this and then go from there.
Thanks
Mar 23, 2022 at 1:25 AM
