Trouble codes
220,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
  • 98 POSTS
I replaced the spark plugs and coil packs. This is what the scan looks like. What do I need to replace now?
Sep 10, 2019 at 4:04 AM
  • 110,251 POSTS
Welcome to 2CarPros.
I hate to say it, but I can't read the codes in the picture. Can you provide the specific codes listed?
Thanks,
Sep 10, 2019 at 12:41 PM
  • 98 POSTS
The codes are:
P1140
P1320
P1140
P1320
P0304
P1130
Sep 10, 2019 at 10:09 PM
  • 110,251 POSTS
Welcome back:
The 304 is still related to cylinder 4 misfire. As far as the 1140, there is an issue with the camshaft position sensor on the right side. Next, the 1130 deals with the swirl valve in the intake. The 1320 deals with a an ignition issue. Okay, the first thing I need you to do is this. Switch the coil on cylinder 4 with another cylinder to confirm this isn't a coil issue. Although it is new, it can be bad.
Next, I need you to check the connections at the swirl valve and the camshaft position sensors. Make sure there are no issues with corrosion or damage.
Since the swirl valve also operates on engine vacuum, we need to check for a leak. Here is a link that shows how to check.
I attached 3 pictures below. The first shows the swirl valve connection, the second shows the vacuum control switch for the swirl valve, and the third is the cam sensor.
I am hoping it is something that may have been left unplugged when you did the work because it will become very complex to diagnose if it isn't. The one thing these things all affect is the timing. I would be happy to attach the diagnostic flow charts for everything, but it will require a good scanner and I don't want to overwhelm you unless you want it.
Let me know what you find.
Sep 11, 2019 at 9:43 AM
  • 98 POSTS
Okay, took the coil pack back and got a new one. Replaced the camshaft position sensor. And blew out all of the vacuum lines connected to the swirl control valve and checked all the connections. Everything looks good. Went to try and get a new swirl control valve, but they don't gave it. And nobody else around here does either. I can get them from one of our pick a part yards. But don't know if this is advisable. these are the codes that I'm throwing now:
P1140
P1130
P1140
P1130
Sep 15, 2019 at 5:55 AM
  • 110,251 POSTS
I hate to ask this, but are you sure you replaced the right cam sensor?
Sep 15, 2019 at 12:52 PM
  • 98 POSTS
Pretty sure I did. When I had AutoZone re-scanned recommended that I change the VVT solenoid. Does this sound right?
Sep 15, 2019 at 1:57 PM
  • 110,251 POSTS
Are you getting any noise from the VVT?
Sep 16, 2019 at 10:20 AM
  • 98 POSTS
I dont have a way to hear it. I'll try using a screwdriver. What kind of sounds am I listening for?
Sep 16, 2019 at 11:40 PM
  • 110,251 POSTS
Usually when it is bad, you will hear a ticking sound or even a slight knock. They may an automotive stethoscope that you can get at any parts store for about five bucks. You will then be classified the Dr. of Motors. LOL Honestly, they work great even though I get laughed at when I use mine.
Sep 17, 2019 at 11:34 AM
