trouble codes
160,000 MILES
HEATHWOLF23
p1744 transmission,p1519 intake manifold runner control fault-stuck closed and p0305 #5 cyl. misfire. I can't find an answer anywhere that gives me any specific inormation on these codes and the posible solutions.thanks
May 11, 2013 at 2:10 PM
HMAC300
  • 48,601 POSTS
1744 is excessive slip in the torque converter clutch so a trans guy wil have to look at that.1519 is intake manifold runner control stuck so check all your air system for air leaks. clogged air filster holes in ductwork etc. for misfire check fuel pressure
May 11, 2013 at 11:16 PM
