Trouble code PO306
195,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DCANEZ
  • 7 POSTS
PO306
I have a miss fire on cylinder 6
I change put the plugs and coil packs , installed a new EGR vavle ,
But I still getting the same code PO306
Any idea to what and try next ?
Also today I got what looks to be a red flashing lighting bolt on the display cluster ...
Feb 9, 2016 at 4:30 AM
JOHNNYT73
  • 924 POSTS
Try disconnecting the battery and leaving it that way for about 10 min. Reconnect and see if does anything. I have seen weird things with chrysler cars and misfires.
Feb 9, 2016 at 4:39 AM
DCANEZ
  • 7 POSTS
Even if after I clear the code I the car still shakes and the code canes back , but I'll try this , I had the battery off when I installed the new plugs coils and EGR valve
Feb 9, 2016 at 4:45 AM
JOHNNYT73
  • 924 POSTS
ok, also try putting in some fuel system cleaner
DCANEZ
  • 7 POSTS
What cleaner do you recommend ?
I put one in STP injector cleaner cuz i was thinking it was an injector issue
Feb 9, 2016 at 4:49 AM
JOHNNYT73
  • 924 POSTS
There are a few. Seafoam, Techron, and Lucas
Feb 9, 2016 at 4:50 AM
DCANEZ
  • 7 POSTS
Ok
I was told about Seafoam was good I'll give it a try ...
But of this don't help
You think it could be the injector ?
Feb 9, 2016 at 4:52 AM
JOHNNYT73
  • 924 POSTS
Possibly
DCANEZ
  • 7 POSTS
Ok thanks
Work just about fixing everything in my cars but
I have never changed out an injector , so I'll have to look it up on how to ... Lol
Feb 9, 2016 at 4:56 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes and freeze frame it by a pro he can check misfires if a sensor is screwed up . the only thing you can do now is check compression an d fuel pressure with a gauge. auto parts rent it.low fuel pressure as well as a vacuum leak can cause these as well as basic engine problems.
Feb 9, 2016 at 7:08 AM
