Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Pathfinder
Trouble Codes
P Codes (Powertrain)
P0400 - P0499
P0420
Trouble code P0420
2014 NISSAN PATHFINDER
146,723 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
KMCCONKEY92
MEMBER
1 POST
Trouble code P0420-Catalyst System: Efficiency Below Threshold (Bank 1).
Jan 1, 2020 at 3:53 AM
Experienced Mechanic
Good evening,
You need the cat converter for bank1. The precious metals are worn out and it needs to be replaced.
If you have less than 80,000 on your car then it is a warranty item.
Images (Click to enlarge)
Jan 1, 2020 at 8:29 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine has low power
