Trouble code P0342?
180,000 MILES
RASHAD RIALS
Hello. Any suggestions? I replaced both my camshaft sensor and crankshaft sensor and I’m still getting the code P0342 with start up trouble. What should I do next??
Mar 7, 2023 at 12:41 AM
  • 110,248 POSTS
The code indicates a low voltage issue to or from the sensor. In this case, it can be a connector issue, a broken wire, a short-to-ground issue, or even a failing PCM.
I don't know what type of tooling you have, but if you have a live data scan tool as well as one that can look up freeze frame data, I attached the diagnostics below specific to this vehicle. Take a look through them and let me know if you are comfortable performing them.
Mar 7, 2023 at 10:26 AM
RASHAD RIALS
Hi. Thank you so much for your response. I am comfortable performing the scans
Mar 8, 2023 at 4:56 AM
  • 110,248 POSTS
You are very welcome. It's no problem at all.
If you have a chance, let me know what you find. I'm interested in knowing. Also, if you have questions, let me know.
Mar 8, 2023 at 11:07 AM
