trouble code for output speed sensor and knock sensor
61,500 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SAMUELM
no issues with driving. speedometer also giving accurate read (tested against a gps). i am due for an inspection and in general would like to keep the car in good health. i switched the knock sensor a year ago and the check engine light deleted the codes and it stayed off. About 3 months ago it gave me the output speed sensor code, i put in a new sensor - it didn't help. The knock sensor code came about a month after that.
Feb 22, 2022 at 6:02 AM
Let's start with getting the actual codes that you have and then we can provide the testing and info needed to figure this out.
In the meantime, here are a couple guides that will help with this info of each system:
https://www.2carpros.com/articles/how-a-knock-sensor-works
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
I assume we are going to be dealing with a wiring issue or a control module but let's start with getting the actual codes and we can go from there.
Thanks
Feb 23, 2022 at 9:35 AM
