Code p1233, engine lost power while driving?
209 MILES • 3.7L • V6 • AUTOMATIC
CANDYBSMITH
I was driving and I lost engine power. Would not go over 2600 rpm's or 30 MPH. Service engine soon light is on now. Scanner shows code p1233.
Feb 13, 2023 at 12:41 PM
BORIS K
  • 836 POSTS
P1233- electronic throttle control bank 2
See image below
This is visible once the engine cover is removed
I would suggest first checking the throttle body for dirt on the butterfly.
Use some throttle body cleaner and clean it off, ensure that there is free movement
Good videos:
https://youtu.be/VAVCwcWHmtA
and
https://youtu.be/vhCSd-T4aSY
Inspect the connector at the throttle body, unclip from throttle body and check for possible corrosion. Clean with electro or contact cleaner
A good guide:
Cheers, Boris
Feb 13, 2023 at 5:04 PM
