Shuts off while driving and will not restart immediately?
250,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
MSPRAYBE
While driving down the road the truck stalls and quits. I tried to restart it and it sounded like it was trying but wouldn't actually start. After pushing it out of the road and it is sitting for about a 10–15-minute time I tried cranking it again and it started but stalled out and died about 30 seconds later. And it is now starting but keeps stalling out after a few minutes of driving.
Jan 23, 2024 at 6:12 AM
  • 110,248 POSTS
This type of issue can be a few things. Most likely, either the crankshaft position sensor is failing, or we have low fuel pressure.
First, take a look through this link and let me know if you feel it mirrors what you are experiencing:
If not, then my next suggestion would be to check the fuel pressure to make sure it is within the manufacturer's specifications.
Here is a link that explains how to check the pressure:
To check the pressure, you will need a fuel pressure gauge. Most parts stores will lend one to you.
I attached the manufacturer's fuel pressure specifications below. Note: The 8th digit of the VIN is the engine code. It will be either a Z or something other. Take note of the pressures based on the VIN engine code.
Let me know your thoughts and if you have other questions,
See pic below.
Jan 23, 2024 at 12:17 PM
