Tried replacing tensioner pulley and serpentine belt and now having major issues
157,000 MILES • 3.5L • 6 CYL • AWD • AUTOMATIC
JOE MCCLOUD
I was trying to replace tension-er pilot. Pulled alternator. Forgot to disconnect battery causing spark. Put alternator back on. Put new serpentine belt on. Now, windows do no work, will not shift out of park because ABS light is on. Radio will not work. Heat and air do not work.
Feb 20, 2017 at 2:50 PM
JOE MCCLOUD
Tension er pulley*
Feb 20, 2017 at 2:51 PM
CJ MEDEVAC
  • 11,000 POSTS
Check fuses and fusible links.
Always replace them with the same size.
The Medic
Feb 21, 2017 at 9:35 AM
