After re-installing the transmission i forgot to put the magnet back in the transmission pan?
256,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
DANIELR
  • 26 POSTS
i changed the transmission fluid filter and while i had it apart the shift solenoid. Everything went well until i put it all back together and filled her back up with fluid i realized i forgot to put the magnet back in the transmission pan. Is that going to mess things up?
Jul 28, 2024 at 5:37 PM
DANIELR
  • 26 POSTS
When I put my truck I to reverse it literally takes 15-30 second to actually feel the truck go I to reverse. Why? What is causing this? I've changed the fluid filter and shift solenoid. Still does it. Help please.
Jul 29, 2024 at 3:48 AM (Merged)
  • 55,542 POSTS
The magnet is used to catch stray metal particles which can cause problems if they get by the fluid filter. The reverse shift problem can be the transmission seals for the reverse band/servo are worn out. I would try a bottle of Lucas transmission saver; my son uses it all the time and says it works great. Let me know how it goes.
Jul 29, 2024 at 3:53 AM
DANIELR
  • 26 POSTS
I'm going to get a bottle of Lucas tomorrow and I'll let u know. Now should u use just Lucas. Like drain what's in it out then refill with Lucas or just drain a small amount out and top it off.
Also my truck taps loudly. Sometimes it doesn't but most of the time it does. It sounds like a lifter to me. I'm wondering if I can take the valve cover off and maybe tighten something down so the tapping stops.
Jul 29, 2024 at 8:27 PM
  • 55,542 POSTS
You can just add the Lucas, it is only a small amount so you should be okay. Also, please start a new question for the tapping noise, and upload a short video to help us see what going on as well.
Jul 30, 2024 at 3:05 AM
