Transmission replacement
128,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
CARHART40
  • 8 POSTS
Will a 2005 3/4 ton transmission fit a 2000 1/2 ton Chevrolet?
Sep 17, 2017 at 6:38 AM
STEVE W.
  • 15,378 POSTS
Not very likely. GM used various transmissions in those years and it depends on exactly which transmission you have now and which transmission the 2005 has.
The 1/2 ton commonly has a 4L60-E transmission while the 3/4 ton usually has the larger 4L80-E to handle the 6.0 engine.
Sep 17, 2017 at 9:39 AM
CARHART40
  • 8 POSTS
Okay thanks. How about a 2005 suburban fitting the 1/2 ton Chevrolet ?
Sep 17, 2017 at 12:02 PM
STEVE W.
  • 15,378 POSTS
Depends on the suburban they came with a variety as well. An easy solution to track a transmission would be to go to car-part.com. Enter your VIN number and the rest of the information. It will show you the years and vehicles that use the same transmission. (it also shows salvage yards with them but you can use the site simply as a parts matching item).
Sep 17, 2017 at 2:18 PM
CARHART40
  • 8 POSTS
Thanks Steve W, very helpful.
Sep 18, 2017 at 5:50 PM
  • 55,583 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Sep 20, 2017 at 4:53 AM
CARHART40
  • 8 POSTS
Sure will thanks
Sep 20, 2017 at 8:04 AM
