Transponder Key
200,000 MILES
JRFIREFIGHTER533
  • 12 POSTS
I have a 99 mercury cougar and the key was broken off in the ignition. The cay will still start with the other half of the key but i was wanting to replace it. I have read that a new key can be programmed at home if you have 2 spare keys but will this work with only 1 broken key? The key is broken near the end towards the grip and does not effect the teeth
May 21, 2013 at 1:11 AM
WRENCHTECH
  • 20,758 POSTS
No, this procedure is for adding a third key to a working system. Once you change the lock, you no longer have any working keys.
May 21, 2013 at 1:54 AM
KHLOW2008
  • 41,812 POSTS
Get a locksmith to fabricate a new key for you and reuse the present transponder.
May 21, 2013 at 3:00 AM
JRFIREFIGHTER533
  • 12 POSTS
Ok, thanks for the quick replies and the information. By chance would you happen to know about how much they a locksmith would charge in I purchased a key myself and had them cut and change the transponder?
May 21, 2013 at 3:29 AM
KHLOW2008
  • 41,812 POSTS
You would need to check with the locksmith to be accurate. Prices varies depending on location.
May 21, 2013 at 3:33 AM
WRENCHTECH
  • 20,758 POSTS
You're still going to have to deal with the broken piece stuck in the lock.
May 21, 2013 at 4:06 AM
JRFIREFIGHTER533
  • 12 POSTS
The locksmith should be able to remove whats left of the key correct?
May 21, 2013 at 7:20 AM
KHLOW2008
  • 41,812 POSTS
Yes, the locksmith would be able to remove the piece from the lock.
May 21, 2013 at 10:08 PM
