I have a 99 mercury cougar and the key was broken off in the ignition. The cay will still start with the other half of the key but i was wanting to replace it. I have read that a new key can be programmed at home if you have 2 spare keys but will this work with only 1 broken key? The key is broken near the end towards the grip and does not effect the teeth
May 21, 2013 at 8:11 AM
