transmission code p0753?
2012 HYUNDAI GENESIS
185,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
BHAMDOC1
  • 351 POSTS
I saw a TSB about the jerking that can take place in these so dropped the valve body and changed the 2 they talk about. Filled it with a gallon of fluid and started it but heard what sounded like starvation from the pan, so added another quart, got a bit better but still noisy. I got code p0753, so I ordered that and ill drop it again to change it. they all come with a plastic black cap, I assume these need to be removed before installing and are just for protection while being shipped? video showing the sound, and a picture to show the cap.
Oct 9, 2025 at 12:17 PM
  • 55,381 POSTS
So the sounds was not there before correct? That is not a fluid sound so there must be something wrong with the valve, it can be defective. Also, where the black cap is that is where the electrical connects correct? So it should be removed before the connector is reattached.
P0753 on a 2012 Hyundai Genesis is “Shift Solenoid A - Electrical
If you have a bidirectional scan tool, use Output/Actuator Test - Shift Solenoid A. You should hear/feel it click and see current draw (0.8 - 1.2 A is common for this style). No click/current = electrical fault.
These are the 8 speed transmission which they had problems with, you may have a mechanical failure which can masquerade as an electrical failure. Let us know how it goes.
Oct 10, 2025 at 1:47 AM
  • 55,381 POSTS
Please respond
Oct 14, 2025 at 5:52 AM
BHAMDOC1
  • 351 POSTS
I wanted to but couldnt due to your issues with the site. Noise was not there before.i ordered the 1st 3 solenoids from oem so i will see how it goes. I removed the valve body again and i hear them click
Oct 14, 2025 at 5:56 AM
  • 55,381 POSTS
Bummer, if the solenoid clicks and does not fix it the transmission has an internal problem which causes the code. It will need to come apart and be rebuilt. I know it says an electrical error but if you hear it working the error is causes by unexpected electrical draw or lack of it while the transmission is in action, this means there is an mechanical failure.
Oct 15, 2025 at 1:33 AM
