I can replace the older transmission with Toyota's newer Multi-Drive 7s transmission?
7 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DE KING
Hello Sir!
i hope you are doing well.
i want to know if i can replace the older transmission with Toyota's newer Multi-Drive 7s transmission, can i do it ?
Dec 30, 2017 at 5:52 AM
  • 31,937 POSTS
I would say no, the mechanical alignments would probably be different and the electronics would not be comparable, you may be able to over come these problems, but at a cost far out weighing the advantages, i have never heard of it being done, you may be able to get some info on Corolla Forums, you may want to try asking a few questions there as well.
May 26, 2021 at 11:14 AM
