How can I change the fluid without taking out the transmission
186,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MONCHO6685
  • 118 POSTS
I have water inside transmission. How can I change the fluid without taking out the transmission?
Jun 3, 2018 at 11:01 PM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com. The only way I know to remove all fluid from the transmission is to power flush the system. Basically, a machine is connected between one of the cooling lines. New fluid is put into the system while the old is removed. If there is water in it, I would also recommend servicing the pan and filter at the same time.
May 4, 2021 at 2:32 AM
MONCHO6685
  • 118 POSTS
Joe thanks for your answer. If I do not have the machine, may I try taking out the line that return to the transmission, put that line in a five gallon pail and recirculate the fluid with the same transmission pump?
I pruchased ten quarts of ATF Mercon V, do I need more for that transmission?
  • 110,248 POSTS
I have to be honest, I do not think it will work, because the pressure of the pump is only one sided. Basically, if you disconnect the line, it will empty the transmission but the other will not draw the new in. It needs to be a closed loop so to say.
I have the machine at my shop. I install sixteen quarts in it every time I do a power flush. Let me ask a question. How did the water get into the fluid and how much water is involved?
MONCHO6685
  • 118 POSTS
The water was in the bucket I have it. My mistake. I think a quart plus or minus. Right now looks pink. Is there is another way to do it without take out the transmission? If you can, give me information about your equipment, send me photos or other things to try to get it. Thanks for your answer. If you have another idea please let me know.
  • 110,248 POSTS
The only other way is to service the pan and filter several times while driving a few miles between services. That will be expensive and time consuming. I attached a picture from online that is the one I have.
MONCHO6685
  • 118 POSTS
Thanks for your teaching and show me new things. When you said machine you really mean it.
Thanks for the picture, let me see what hurts, the price.
  • 110,248 POSTS
Not a problem. Just to give you an idea, on average I charge $150.00 for a power flush. However, I am near Pittsburgh, PA so I do not know what you can expect. Regardless, hopefully that will give you some guide of cost.
MONCHO6685
  • 118 POSTS
Good morning Joe, thanks for your help. My expectation, be as good mechanic as possible. And now you are part of my learning.
Thanks. Juan Marin
  • 110,248 POSTS
Juan.
I am glad to help in any way I can. It is funny, I have a shop and work on them all the time, but I am also a teacher. LOL. I love cars and after nearly forty years of working on them, I still enjoy it.
Take care and if I can help in the future, please let me know.
MONCHO6685
  • 118 POSTS
Thank you very much for your help. We learn new things everyday. Forty year that is a lot of time and experience. I need to learn more. I am glad to know people who love what they do, because is not a job is like a hobby. That is my goal. Thanks. We are in touch.
