Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Cherokee
Engine
Symptoms
Not Running
Vehicle does not move forward or backwards
1999 JEEP CHEROKEE
223,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
WILLIAMWOOLERY1953
MEMBER
1 POST
Motor runs fine but will not move forward or back.
Aug 24, 2018 at 2:48 PM
Experienced Mechanic
Good morning.
Some possible causes.
1. Low fluid level.
2. Clogged filter in the transmission pan.
3. Front pump.
4. torque converter failure
5. Driveshaft or differential failure.
All these need to be checked. In most cases, it is the internal failure in the transmission.
Aug 25, 2018 at 12:38 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
