Transmission Value body removal
223,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
MCKINNEY60
I have removed the value pan on the transmission removed the hex bolts and then removed the wiring going into the transmission the value body has play, but will not come out of the transmission. i am doing this to replace the shift solenoid.
Nov 19, 2016 at 11:51 AM
HMAC300
  • 48,601 POSTS
scan for codes first then put bolts back on either front or back loose so you do not get a bath in oil. then use a razor knife to cut the sealant between pan and case, then pull down area with out bolts.
Nov 20, 2016 at 7:47 AM
