Good evening.
There is a rod on the throttle body that controls the valve in the valve body for shifting. make sure it is connected and not laying down on the manifold.
5.OL HO and SEFI Engines.
The throttle valve (TV) control cable system consists of a cable attaching grommet on the throttle body throttle lever, the TV control cable Cassembly, the external TV control lever on the transmission, and the cable mounting brackets at the throttle body and transmission.
imageZoom/Print
As the throttle is moved from idle to wide-open throttle (WOT), the TV control cable pulls the transmission TV control lever from idle to WOT. Return of the cable and transmission lever toward idle is accomplished by the return spring on the transmission end of the cable assembly. This spring and the end of the cable assembly is protected by a flexible rubber boot. The transmission external TV control lever actuates the Internal TV control mechanism which regulates the TV control pressure. The travel of this lever is controlled by stops internal to the transmission.
The TV control cable is set and locked to its proper length during initial assembly when the grooved pin on the upper end of the cable assembly is inserted in the grommet on the throttle body lever. To release the cable locking mechanism, it is necessary to pry the grooved pin out of the grommet and push out the white locking pin. The take-up spring at the end of the cable assembly tensions the cable and takes up the slack in the system. When the grooved pin is reinserted in the grommet, the white locking tab is pushed in, automatically locking the cable to its correct length. When the cable is locked, the take up spring plays no part in the operation of the system.
Under normal circumstances, it should not be necessary to alter or readjust the initial setting of the TV control cable. Situations requiring readjustment of the TV control cable include maintenance involving the removal and/or replacement of the throttle body, transmission, TV cable assembly or installing a new main control assembly. Readjustment of the TV control cable would also be i.'ecessary to correct cbmplaints of poot transmission s**** quallity that would have been caused by a misadjustment of the TV control cable.
When the TV control cable is prperly set, the transmission Tv control lever will be at its internal idle stop (lever to rear as far as it will travel) when the throttle lever is at its idle stop.
Idle Speed Affect on TV Control Cable
The 5.0L and 5.OL HO (302 CID) SEFI engine uses an Air Bypass (ISC) that does not affect throttle position. Therefore, idle automatic setting does not affect TV cable adjustment.
TV Cable Linkage Adjustment Self-Locking (Core Wire Adjustment)
1. Remove air cleaner cover and inlet tube from throttle body inlet to access throttle lever and cable assembly.
2. Using a wide~blade screwdriver, pry grooved pin on cable assembly out of grommet on throttle body lever.
imageZoom/Print
3. Using a small screwdriver, push out white locking tab.
imageZoom/Print
4. Check to ensureplastic block with pin and tab slides freely on notched rod. If it does not slide freely, the white tab may not be pushed out far enough.
imageZoom/Print
5. While holding throttle lever firmly against its idle stop, push grooved pin into grommet on throttle lever as far as it will go.
NOTE: While pushing pin into grdmmet, make sure you do not move throttle lever away from idle stop.
6. Install air cleaner cover and airinlet tube.
imageZoom/Print
Linkage Adjustment Using Throttle Valve TV Control Pressure
NOTE: This procedure requires the use of TV Pressure Gauge with Hose (0-60 psi) T86L-70002-A or equivalent. The results of the adjustment procedure depends on the accuracy of the pressure gauge.
A pressure gauge should be checked periodically (approximately once a year) or when the following occurs:
1. The needle will not return to 0 kPa (0 psi) under no pressure.
2. The needle goes past 0 kPa (0 psi) (negative side) under no pressure.
3. Bumping or dropping a pressure gauge.
Adjustment and/or Check
1. Attach TV Pressure Gauge with Hose (0-60 psi) T86L-70002-A or equivalent, to the TV port on the transmission.
NOTE: If service tool is not available, in order to avoid the exhaust system, obtain the following material and assemble as shown:
^ One 1/8-inch NPT female Hansen fitting
^ One 1/8-inch NPT male Hansen fitting
^ One 1/4-inch NPT 90 degree elbow connector
^ One high-pressure hose fitting
The pressure gauge should have 2.4m (8 feet) of flexible hose to make the gauge accessible while operating the engine.
2. Remove the air cleaner cover and inlet tube from the throttle body inlet for easier access to throttle lever.
3. Insert tapered end of the tool between the crimped slug on the end of cable and plastic notched rod, also on end of cable assembly. Push in Cable TV Gauge Tool T86L-70332-A, or equivalent forcing the crimped slug away from the plastic rod. Ensure gauge block is pushed in as far as it will go.
Aug 8, 2020 at 5:38 AM
(Merged)
