my problem is, the car does not move if the gear lever is shifted to either drive or reverse.
Sep 6, 2016 at 4:23 PM
HMAC300
✓Experienced Mechanic
make sure transmission is shifting first then have a transmission professional look at it, he has to check fluid anyhow as there may not be a dipstick. if it moves in any gear it may be in limp mode which a scanner will need to be attached or it is an internal problem.
