Transmission will not shift to third and fourth when warm
216,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
TNB13
I have the vehicle listed above it is supercharged h.o. pos. When cold the transmission shifts through gears like normal. After I drive it for five minutes suddenly it will not shift out of second into third. While I can hear the engine sounds as if it is going to shift I do no't hear or feel the transmission do anything. If I go to fast the car will jerk a little as if I slammed my brakes (I do not drive it because of this. I was only testing it out after replacing the TPS. It is good on fluid and even put Lucas transmission treatment in it. What would you recommend doing?
Feb 16, 2018 at 12:28 AM
Good afternoon.
The first thing I would do is change the transmission oil and filter and add a can of valve body modifier and see if that takes care of it.
It could also be a failing seal or piston in one of the drums.
Feb 16, 2018 at 1:31 AM
  • 55,858 POSTS
This can be a shaft speed sensor. Can you run the codes to see what comes up?
Cheers, Ken
Feb 16, 2018 at 2:19 AM
