Transmission will not shift
280,000 MILES • V8 • 2WD • AUTOMATIC
SPS354
Replaced transmission, ran fine, until I wiggled headlight switch to make them come on. The fuse box is loose in its housing. Bad wiring or speed sensor or both?
Dec 15, 2018 at 2:46 PM
  • 55,746 POSTS
It could be can we run the codes to see what comes up?
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Check the fuses and fix any loose wiring and report back. Please let us know what you find
May 14, 2021 at 4:23 AM
