Transmission will not go in gear
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROCKY BILLBE
Reverse quit, then drive and 3rd gear then 1st gear, turn off car for a few minutes and the forewarned gears work for a short period of time, then quit again.
Apr 15, 2017 at 4:38 AM
  • 55,676 POSTS
Please check the transmission fluid level, if okay then scan the PCM for trouble codes to see if it has to do with the computer.
Here is a guide to help you.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 17, 2017 at 9:21 AM
