Transmission will not downshift for power
160,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MATTHEWS73
  • 7 POSTS
Traveling at sixty mph I increase pressure on the accelerator to pass, the car bogs and will not downshift. If the pedal pressure stays moderate the transmission shifts smoothly up and down.
Feb 5, 2018 at 1:35 AM
  • 55,808 POSTS
It sounds like you have an input shaft speed sensor that is going out but to be sure lets run the codes to see what codes up. Here is a guide to help us get started:
Here are the transmission wiring and speed sensor location.
Check out the diagrams (below).
Cheers, Ken
Feb 6, 2018 at 4:03 AM
MATTHEWS73
  • 7 POSTS
The only code I get is P0443 about the Purge Control Valve- checked again yesterday. I heard it might go away by resetting the computer and so disconnected the battery for 1+ hour but the symptom remains. I replaced the Purge Control Valve several weeks ago- probably need to look at the electrical connection since it is still coding.
Feb 11, 2018 at 11:32 PM
MATTHEWS73
  • 7 POSTS
Hi Ken, thanks for responding.
Feb 11, 2018 at 11:33 PM
  • 55,808 POSTS
Do me a favor with the engine running disconnect the vacuum line to the valve to see if there is engine vacuum present.
Feb 12, 2018 at 2:26 AM
MATTHEWS73
  • 7 POSTS
Yes there is vacuum. The wires look ok, the retaining clip snapped off the head but it seats well and does not slip out unless pulled.
Feb 16, 2018 at 4:45 AM
  • 55,808 POSTS
Can you connected power and ground to the solenoid to see if it works? You should hear a click and then be able to blown through it.
Feb 17, 2018 at 2:58 AM
MATTHEWS73
  • 7 POSTS
There is a click, the solenoid operates connected to a 9v battery. Its old but the vacuum lines look ok.
Mar 4, 2018 at 5:01 AM
  • 55,808 POSTS
I sounds like you may have a PCM going bad not shifting and the EVAP error. If you clear the codes and then turn the key on without starting the car does the code come right back?
Mar 5, 2018 at 2:47 AM
MATTHEWS73
  • 7 POSTS
The code remained clear for more than a day, but came back while attempting a minor acceleration at 60+ when the gear selection stuttered.In this situation I can press the pedal to the floor and the car will kick down and accelerate rapidly. The same3 thing happened near 30-35 mph on an onramp, looking to sort position, a little more pressure on the pedal resulted in stuttering acceleration until pressure was let up. Service engine light flashes in these instances- about 30 seconds then remains lit steady.
Mar 22, 2018 at 12:35 AM
  • 55,808 POSTS
I had a thought, it could be you have a plugged catalytic converter which can cause the low power and shifting issues, Can you run this test and report back?
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please run down this guide
Cheers, Ken
Mar 22, 2018 at 3:21 AM
MATTHEWS73
  • 7 POSTS
Holy Moley I found it! My son talked me into replacing the Throttle Position Sensor which had no effect, so I took it to a shop. Hooked up to diagnostic equipment, with the brake depressed and throttle applied (loaded) the #3 cylinder was misfiring consistently, right off the screen. But no code would come. Replaced the #3 coil and all is good! No clue why it wouldn't code properly. Appreciate your effort and time, thanks and take care!
Apr 9, 2018 at 1:37 AM
  • 55,808 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Apr 9, 2018 at 3:55 AM
