Needing to replace my neutral safety switch wiring and check wiring for whole transmission.
Apr 25, 2020 at 5:24 AM
✓Experienced Mechanic
I attached the wiring diagrams from Ford on the transmission. Let me know if you need more info and we can get it for you. Thanks
FYI - The neutral safety switch on an automatic is called a digital transmission range sensor. Others call it a transmission position switch or just a range sensor.
Images (Click to enlarge)
Apr 25, 2020 at 5:53 AM
FORDRIDINHIGH88
MEMBER
1 POST
I have a 92 f-250 7.3L diesel and the wiring harness from the transmission somehow got wrapped around the axle and pulled some of the wires out of place. I can not find this particular wiring diagram anywhere is there any place that it can be located.
Thanks!
Jul 27, 2020 at 10:11 AM
(Merged)
HMAC300
Here are the transmission wiring diagrams and a guide to help you test the connections.
(Merged)
J.STIEG
MEMBER
I am having some problems with my 92 ford truck I just put a transmission in it from a 94. I think the torque convertor lockes up right after I put it in gear. connectors fit but looked different. diagrams would help. thanks!
(Merged)
FIXITMR
do wire colors in plugs match?
(Merged)
J.STIEG
MEMBER
there are only wires on one side.
(Merged)
FIXITMR
and did you do any research as to interchangability before the swap?
(Merged)
FIXITMR
what motor is in it. it's 2 or 4wd?
(Merged)
J.STIEG
MEMBER
the salvage yard matched it up for me. It has a 5.0l engine. maybe the range sensor is messed up or the wrong one.
I just need a diagram so I can see what I have. Can you help?
(Merged)
J.STIEG
MEMBER
4wd as well.
(Merged)
FIXITMR
did you consider switching range sensors?
(Merged)
J.STIEG
MEMBER
Yes, I will call the salvage yard tomorrow to see if they still have it. the truck will barely take off
(Merged)
FIXITMR
does this help?
Image (Click to enlarge)
(Merged)
FIXITMR
that was 94 schematic, here is 92.
(Merged)
J.STIEG
MEMBER
I found out whats going on but not shure whats causing it. the engine is only running on 4 cylinders at times. The computers ground pulse is cutting out on cylinders 2, 3, 6, and 7. This is all happened when I put the transmission in. Truck runs bad now, Any ideas to further troubleshoot this problem?
(Merged)
J.STIEG
MEMBER
I forgot to mention that it was the fuel injectors that are not being driven by computer.
(Merged)
FIXITMR
those cylinders are ground bank #2 from computer the other 4 cylinders are bank 1. check output right at computer pin 69 (white wire) next to it is pin 68 (tan wire bank #1) if good wiring/connections are suspect.
