Transmission will not ingage into drive
90,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
THOMAS CLARK4
I let car sit for 2 years and transmission was strong,got it started and transmission would slip on take off.Went around block and parked it.Next day car would not even go into drive,but went into reverse fine.Bought and changed all solenoids,filter and speed sensors.But still no drive,only reverse.
Sep 27, 2019 at 5:47 AM
94 TRANSAM
  • 680 POSTS
Hi welcome to 2CarPros.
Have you plugged in a scanner to see if you have any transmission codes?
Here is a guide to get you started:
Rich
Sep 28, 2019 at 4:05 AM
THOMAS CLARK4
Did plug in scanner but no codes came up.
Sep 28, 2019 at 8:35 AM
94 TRANSAM
  • 680 POSTS
Transmissions are tough to diagnose because many things can cause the same symptoms and 90% of those things are inside it. Based on what you are telling me I would say the most likely would be the internal seals dried out and cracked and you are losing internal pressure which would require a rebuild.
It is possible but less likely that a valve in the valve body is hanging up. You could drop the valve body and go through it as a last ditch effort before dropping the transmission.
Newer seals can sit but once they get this kind of mileage on them they dry out and the only thing that keeps them alive is the hot oil they are continuously soaked in. When that stops they simply shrink and crack.
Let me know what you find out or if you need any help with the valve body.
Rich
Sep 28, 2019 at 12:06 PM
THOMAS CLARK4
Luckily one of my dad old friends showed up for a visit and he is a 35 year transmission re-builder. So I asked him and he said that the clutch plates are notorious for crumbling in this transmission.So we are going to pull it out and he is going to tear it apart and see what he can find out.I will post updates as it goes.Maybe a few weeks as I am installing a new motor in my 1987 Buick.
Sep 28, 2019 at 11:53 PM
94 TRANSAM
  • 680 POSTS
Great, keep us posted. We like to know what goes wrong so we can log it to the memory banks.
Rich
Sep 29, 2019 at 2:39 AM
