Transmission whine
140,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BURNIN1961
The transmission does not seem to want to shift into high gear, I feel the first to second and the second to third shift, but nothing after that. The rpm's are at 2,000 at 70 mph. I had the codes read it was P061. Camshaft/crankshaft sensor is bad. Is this possible?
May 23, 2016 at 12:58 PM
HMAC300
  • 48,601 POSTS
there is no code p061 go to auto parts have them scan it and then get back us. if it is a P016 then crank/cam sensor is out of correlation and a local professional will have to set it with the scanner. have it re scanned. It may be your torque converter clutch is not applying for whatever reason.
May 23, 2016 at 11:27 PM
BURNIN1961
Hello HMAC300. You are right my dyslexia kicked in it was a P016 code. Would replacing the Cam sensor cause the vehicle to shift better or at least make it to high gear so it did not scream so loud?
May 24, 2016 at 2:53 PM
HMAC300
  • 48,601 POSTS
you can't replace the cam sensor to fix the 016 code it's like the engine is out of time and needs to be retimed. you can't do it because it takes a pro scanner to do it it is done with the machine. I doubt it will have anything to do with your whine. you may have a reaction carrier(planetary gear set) going bad
May 24, 2016 at 11:13 PM
BURNIN1961
Should the 3-4 shift be as detectable as the others, I can feel and hear the 1-2 and 2-3 shifts but after that it just sounds like it's running high but the RPM meter shows 2500 at 70mph. I heard about a TCM grounding issue could this be an issue for me, if you have any details on that can you post something a diagram or something..... Thank you......
May 25, 2016 at 6:24 AM
HMAC300
  • 48,601 POSTS
if you are running 2500 at 70 then your converter clutch may not be applying have a trans guy check this out.
May 25, 2016 at 9:03 AM
