Transmission warning lights blinking
168,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
SPARTA CUZZ
Check transmission light started blinking. the next day blinking stop runs normal the whole day, then next day blink again. this it slowly pick up speed then next day runs normal now started blinking again.
Dec 1, 2019 at 12:21 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I does sound like you have a transmission code stored in your vehicles computer.Here is a tutorial showing how to check the codes on you obd1 Honda:
https://www.2carpros.com/articles/honda-car-1990-1995-obd1-code-retrieval-procedure-and-definition-table
After you perform this procedure get back to me with the code number and we can properly diagnose the issue.Hope this helps and thanks for using 2CarPros.
Dec 1, 2019 at 10:26 AM
