Transmission vibration?
184,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
SAMGREW
  • 59 POSTS
When accelerating the car vibrates side to side. Also, when turning left but not right.
Mar 13, 2024 at 8:49 AM
  • 110,248 POSTS
It could be the transmission is slipping, but that doesn't explain the turning issue. Also, when you say it vibrates side to side, I'm not sure I understand what is happening. Do you mean the front of the vehicle moves left and right? If so, have you checked the suspension and steering components?
I attached a pic below showing different things related to the suspension. Check to make sure everything is tight. Next, I circled the engine cradle or sub-frame. Check to make sure nothing is rusted, the bushings are in good condition, and the general overall condition appears to be fine.
See pic below.
Mar 13, 2024 at 1:08 PM
SAMGREW
  • 59 POSTS
Turned out to be rear transmission mount bolts had vibrated out.
Apr 7, 2025 at 3:15 AM
  • 110,248 POSTS
Wow, that's actually great news. LOL I'm glad you found it and it wasn't a major issue.
Take care of yourself, and feel free to come back anytime in the future.
Apr 7, 2025 at 1:07 PM
