Vehicle details: 4WD / AWD
I’m looking for some transmission-specific input on a shifting issue that changed significantly after replacing the valve body.
The engine seized due to a defect at approximately 178,000 miles. Before that failure, the transmission operated normally, with no slipping or harsh shifts. The dealer replaced the engine and performed a transmission flush while the vehicle was there.
A couple of months later, It started an intermittent harsh shift, it felt like around third gear. Initially, it happened only every 4 to 5 days. It progressed to an RPM flare followed by a hard engagement. Under light throttle and gradual acceleration, the transmission generally shifted normally and done fine. The slipping and harsh engagement became more frequent after another 20 days or so. There were no transmission codes initially, but after a 6th harsh shift, it set P0733—third-gear incorrect ratio.
I removed the original valve body and noticed what appeared to be cracks. I would appreciate input on whether those marks could indicate a hydraulic leak contributing to the original symptoms.
Update: I replaced the valve body, and the vehicle now has no movement in either Drive or Reverse. I can feel what seems to be engagement when selecting either range, but the vehicle does not move. I double-checked my work throughout the replacement and compared the fluid-port locations between the original and replacement valve bodies; they matched.
While disassembling the original valve body to inspect the solenoids, I found one solenoid with its end cap off and sitting inside the bore. I’m unsure which circuit or shift functions that solenoid controls. Before disassembly, all solenoids passed my resistance checks. My understanding is that two should measure approximately 10 ohms and the others approximately 5 ohms, although I would appreciate confirmation of the correct specifications for this transmission.
I’m looking for help with the following:
1. Solenoid identification: Does anyone have a labeled valve body diagram showing each solenoid’s location, function, and involvement in the different gears? Could the detached end cap explain the original flare and harsh shift despite an acceptable resistance reading?
2. No movement after replacement: Given that the transmission moved in all ranges before the valve body replacement, what installation checks or hydraulic tests would you prioritize now? The immediate change makes me suspect an issue involving the replacement valve body or its installation, but I’d like to establish the cause before replacing anything else.
3. Suspected cracks: What should I look for to distinguish actual cracks from casting marks on the original valve body?
4. Cooler-line routing: Does the connection orientation matter on this setup? The cooler mounts to the transmission pan, and I disconnected the hoses at the pipes beneath the battery tray. I believe the upper hose connected to the left pipe and the lower hose to the right pipe. Can anyone confirm the routing, preferably with a diagram or photo and the viewing direction identified?
Any transmission-specific diagrams, pressure-test procedures, or suggestions for the next diagnostic step would be appreciated.
Images (Click to enlarge)
Nov 21, 2026 at 6:17 PM
(Merged)
