p0733?
94,044 MILES • 3.3L • V6 • 2WD • AUTOMATIC
ARTUAX
  • 5 POSTS
Hello, I am having an issue with my van. I was driving home last night and it went into limp mode. Shifting was harsh as it went from third to what felt like first then to second and then stayed in second. I have dropped the pan, changed the transmission filter, fluid, gasket, both output/input sensors and reset the check engine light. After a short road test, the light came right back on. My ABS light is on and has been since I purchased the van six months ago. It is the left rear ABS wheel speed sensor as I found out today. Could this be causing the issue after such a long amount of time or should I try the solenoid pack? Any help would be greatly appreciated.
Nov 17, 2017 at 6:25 AM
CARADIODOC
  • 34,413 POSTS
P0733 - Gear 3 Incorrect ratio
P0734 - Gear 4 Incorrect ratio
These codes set when there is excessive slippage in a clutch pack. The transmission computer knows engine speed, (actually input shaft speed), and it knows which gear is activated. The gear ratio of each clutch pack is programmed in. Based on all that information, the computer knows what road speed, (output shaft speed), should be for a given input shaft speed. Those two will not agree when a clutch pack is slipping.
You can get an idea of the cause of the problem by observing when it goes into limp mode. If there is an electrical problem, such as a broken wire or corroded connector terminal, it will go to limp mode the instant you shift to "reverse" or "drive". The check engine light will turn right back on as soon as it completes the six-second bulb test. Code 700 in the engine computer just means there are other codes in the transmission computer.
If there is a mechanical problem with a sensor, such as metal filings built up on the tip, or an air gap that's too big, those will prevent it from developing a signal voltage even though electrically, everything is okay. That will not be detected until the computer sees the vehicle is moving. The check engine light will remain off as long as the van is standing still, even if it is in "reverse" or "drive".
If the check engine light is off when you drive off, and it starts out in first gear, everything electrical is working up to this point. When it bangs to second gear, (limp mode), and the check engine light turns on, look for what is taking place at that instant. Most commonly that is an up-shift under light to moderate load. The clutch plates wear a little each time the clutch pack engages. On older vehicles we had a good two years warning that was occurring by the "engine runaway" between shifts. Engine speed jumped up higher than normal while it was waiting for the next clutch to engage. With your design, which was a Chrysler innovation for the 1989 model year, the computer learns how much fluid volume it takes to apply each clutch pack, and it constantly updates those numbers as the wear takes place. To address that engine runaway, it will apply third gear, for example, a little sooner, and wait a little longer before it releases second gear. The result of that overlap is a nice crisp, solid shift, until it cannot update any further. The drawback is you do not get that two-years of warning that a rebuild is in your future. One day it shifts perfectly; the next day it goes to limp mode.
A transmission specialist can tell if I'm right by reading the "clutch volume index", (CVI), on a scanner. That is a set of four numbers representing the volume of fluid it takes to apply each clutch pack. As more and more clutch plate material wears off, more fluid is needed to squeeze the plates together.
You may be able to bypass the problem for a little while by accelerating a little harder than normal to delay an up-shift, then let off the accelerator pedal to let it up-shift under no load. The reduced torque will reduce the chance for the clutch pack to slip. If it does go to limp mode, you must turn the ignition switch off, then restart the engine to get it out of limp mode.
Nov 17, 2017 at 8:48 AM
ARTUAX
  • 5 POSTS
Everything works great from a fresh start. It shifts fine until possibly fourth gear. When I reset the code and road test, first is fine, second is fine, it shifts to third just like normal, tries to go to fourth and just goes haywire. Downshifts to what feels like first and then the check engine light comes on. I have tried the trick you suggest to no avail. I will look in to getting a clutch pack. Thank you for your fast and very informative response.
Nov 17, 2017 at 9:10 AM
CARADIODOC
  • 34,413 POSTS
You do not actually buy a clutch pack. The fiber and steel plates inside each of the four clutch packs are replaced, along with a lot of rubber seals, as part of a rebuild.
Talk with the specialist first. If there is a problem with one of the solenoid-controlled valves, fluid pressure to apply that clutch may not rise high enough to lock the plates together efficiently, but that should set a different fault code as monitored with a pressure switch.
They did have a lot of trouble with this transmission in the early years, but at the mileage you listed, it seems too early to need to rebuild the transmission. I would have more faith in what the specialist has to say if you see him connect a scanner to read the clutch volume index before he suggests a plan of attack.
Nov 17, 2017 at 9:45 AM
ARTUAX
  • 5 POSTS
Thank you for the clarification. I will talk to a specialist first and figure out what needs done. Might be my first rebuild. Thanks again for all your advice and the much needed information.
Nov 17, 2017 at 9:52 AM
  • 55,673 POSTS
Cheers, Ken
Nov 20, 2017 at 1:39 AM
ARTUAX
  • 5 POSTS
I will. I have an appointment with a specialist tomorrow.
Nov 20, 2017 at 1:46 AM
  • 55,673 POSTS
Cheers, Ken
Nov 22, 2017 at 1:13 AM
ARTUAX
  • 5 POSTS
Ok, took it to the shop they scanned to install a new input shaft speed sensor, fix it up.
Nov 22, 2017 at 9:51 AM
PITARRA
my 2003 dodge caravan with automatic transmission and with 103000 miles is showing a error code of P0700 and PO731 what is this codes and what does it mean? will i need to replace my transmission? i need help please
Jul 6, 2020 at 6:55 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
This means you need to replaced the transmission input shaft speed sensor. Here is a video of the job being done so you can see what you are in for when doing the job.
https://youtu.be/f3bETtCIdxM
Here is the location for your car.
Check out the diagrams (Below)
Cheers
PITARRA
Thanks for the tip it fixed the car now Im off to work thanks again!
SHANEDCAT
my 2003 dodge caravan has the obd2 code p0725 come up speed input sensor parts store say they only have one sensor but manuel says there are 2 are they the same
CARADIODOC
  • 34,413 POSTS
Yup, there's two and they are different. Input speed sensor and output speed sensor. They refer to engine speed and axle shaft speed.
BMRFIXIT
  • 19,053 POSTS
check the picture
GOMOPAR
Computer problem
2002 Dodge Caravan 6 cyl Two Wheel Drive
2002 3.3L engine recieved codes po725 and po700. Engine code po725 listed no rpm's registering even though the engine was running. Replaced crank position sensor and reset codes, still po725 and po700 comes up. What next?
Jul 6, 2020 at 6:56 AM (Merged)
ZACKMAN
  • 4,202 POSTS
Any particular reason why you replaced the CKP sensor, when both the codes refers to the transmission?
P0700 Transmission Control System Circuit. Your transmission control module.
P0725 Engine Speed Input Circuit Error. Possible from P0700 and/or input speed sensor.
REALPIC
Transmission problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic
change inpout speed sensor and crank sensor run great 2 days ,same code return(P0700 & P0725) transmission no shift
ZACKMAN
  • 4,202 POSTS
Try this diagnostic.
https://images.2carpros.com/forum/automotive_pictures/55316_02caravanp0700_1.jpg
DTC P0725: ENGINE SPEED SENSOR CIRCUIT NOTE: Crankshaft position (CKP) sensor signal may also be know as EATX RPM signal. NOTE: Ensure PRE-DIAGNOSTIC CHECK has been performed before proceeding with the following procedure. Circuit Description DTC P0725 will set when engine speed is less than 390 RPM or greater than 8000 RPM for more than 2 seconds with engine running. Possible Cause  Open crankshaft position sensor signal circuit.  Crankshaft position sensor signal circuit shorted to ground.  Crankshaft position sensor signal circuit shorted to voltage.  Malfunctioning TCM.  Malfunctioning PCM. Diagnostic Procedure 1. Using scan tool, read PCM DTCs. See appropriate SELF-DIAGNOSTICS article in ENGINE PERFORMANCE. If any crankshaft position sensor DTCs are present, diagnose and repair fault before proceeding. If no crankshaft position sensor DTCs are present, go to next step. 2. Using scan tool, check STARTS SINCE SET counter. If counter is not set to zero, go to step 8. If counter is set to zero, go to next step. 3. Turn ignition off. Disconnect TCM and PCM harness connectors. Measure resistance of crankshaft position sensor signal circuit between TCM and PCM harness connectors. See WIRING DIAGRAMS. If resistance is less than 5 ohms, go to next step. If resistance is not less than 5 ohms, repair open in crankshaft position sensor signal circuit. 4. Measure resistance between ground and terminal No. 6 (crankshaft position sensor signal circuit) at TCM harness connector. If resistance is less than 5 ohms, repair crankshaft position sensor signal circuit for short to ground. If resistance is not less than 5 ohms, go to next step. 5. Connect TCM harness connector. Ensure PCM harness connector is disconnected. Turn ignition on. Measure voltage between ground and crankshaft position sensor signal terminal at appropriate PCM harness connector. See WIRING DIAGRAMS. If voltage is 10 volts or less, go to next step. If voltage is greater than 10 volts, repair crankshaft position sensor signal circuit for short to voltage. 6. Measure voltage between PCM harness connector ground and crankshaft position sensor signal terminals. Ensure ignition is on. If voltage is 4.5-5.5 volts, replace PCM. See appropriate REMOVAL, OVERHAUL & INSTALLATION article in ENGINE PERFORMANCE. If voltage is not 4.5-5.5 volts, go to next step. 7. If not problems have been found, replace TCM. See TRANSMISSION CONTROL MODULE under REMOVAL & INSTALLATION. Perform SHIFT QUALITY QUICK-LEARN PROCEDURE and PINION FACTOR PROCEDURE under PROGRAMMING. 8. Conditions needed to set DTC P0725 are currently not present. Perform wiggle test to diagnose intermittent or poor connections. Repair as needed. If no problems are found, testing is complete.
