After rebuilding transmission there is no reverse and will only shift into D?
240,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
HANKSPATRICK
If I pass it up and go to first, I can feel it shift but does not move unless I go back to D. Then truck will start moving forward. What could the problem be?
Sep 14, 2022 at 8:10 PM
MIKE H R
  • 3,094 POSTS
With it not shifting unless you to 1 then to drive when you go to D. I would check the linkage and cable.
Sep 15, 2022 at 1:05 AM
HANKSPATRICK
I checked the linkage and cable and adjusted the shifter cable and adjusted the heat range sensor on the side of the transmission. Nothing has changed and still no reverse at all. I drove it and it does shift gears when driving and OD off light is flashing.
Sep 15, 2022 at 2:32 PM
MIKE H R
  • 3,094 POSTS
Sounds like the reverse sensor.
Here is an article to help you:
Sep 15, 2022 at 11:56 PM
HANKSPATRICK
Where is the reverse sensor located. I also can not find the obd 1 diagnostic plug under the hood anywhere. Where could it be?
Sep 16, 2022 at 4:17 PM
MIKE H R
  • 3,094 POSTS
look down at the transmission. You will see a cable that attaches to a lever. look under that. You will see a black plastic part with a wire connector plugged in.
Sep 16, 2022 at 11:15 PM
