Transmission/trans-axle
150,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
DIESELDADDY
Overdrive light blinking checked codes says p0705 cleaned sensor, plugs, added dielectric grease to connections. any advice?
Aug 26, 2017 at 12:12 PM
  • 55,716 POSTS
This is a code for the transmission selector switch which sounds like it has gone bad, here is a guide and some diagrams (below) of how to get the problem fixed.
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
and
Here is the wiring diagram and how to change it, that's what I would do.
Please check it out and get back to me.
Cheers, Ken
Aug 28, 2017 at 10:06 AM
