Transmission system
20,000 MILES • 2.6L • V6 • 4WD • AUTOMATIC
MAYOWA
My gear delayed in engagement.
Dec 4, 2017 at 1:26 AM
  • 31,937 POSTS
This can be many things, but firstly you need to get the oil level checked. do you see any signs of external leaks on our under the transmission? also, get a transmission scan don for any fault codes. any work that is required on this transmission will have to be done by a qualified tech, as they are very complex and you require many special tools to do even basic test.
Dec 4, 2017 at 6:20 AM
