Transmission swapping
124,607 MILES • 5.0L • V8 • 2WD • AUTOMATIC
DENNIS ALLEN2
Can you replace the transmission with a 2003 F150 transmission?
Dec 27, 2021 at 2:58 PM
Good morning,
I attached the transmissions available for both trucks below.
https://www.2carpros.com/articles/how-to-remove-an-automatic-transmission-rwd
You need to replace it with the exact transmission you currently have at the moment.
There is a tag on the side of the transmission that identifies the model.
Check the tags and let me know.
Dec 27, 2021 at 5:49 PM
BEBAW_79
I want to swap a transmission from a 09 F150 4x4 to a 01 F150 4x4 both have 4.6 liter engines.
Aug 20, 2022 at 6:50 PM
  • 55,694 POSTS
Do they look the same and do they have the same electrical connector? If so, then they should work, let me know if you have any more questions about the installation. Check out this video, it should help:
https://youtu.be/3vJAojsrfuU
Aug 23, 2022 at 4:38 AM
