You need to replace it with the exact transmission you currently have at the moment.
There is a tag on the side of the transmission that identifies the model.
Check the tags and let me know.
Images (Click to enlarge)
Dec 27, 2021 at 5:49 PM
BEBAW_79
MEMBER
1 POST
I want to swap a transmission from a 09 F150 4x4 to a 01 F150 4x4 both have 4.6 liter engines.
Aug 20, 2022 at 6:50 PM
✓Experienced Mechanic
Do they look the same and do they have the same electrical connector? If so, then they should work, let me know if you have any more questions about the installation. Check out this video, it should help:
