Will a manual transmission from a 99 dodge Dakota replace an automatic transmission in a 99 dodge Durango?
Apr 15, 2023 at 5:51 AM
✓Experienced Mechanic
If they have the same engine size and both are 2wd, it should work. However, you need to install a clutch pedal as well as the shifter. Additionally, the driveshaft may need modifications when it comes to length.
The Durango has a 5.9L. I wouldn't recommend using the transmission from a 4-cylinder or the 3.9L engine.
Let me know if I can help.
Apr 15, 2023 at 3:23 PM
MARCHER80
MEMBER
Got it in but won't crank up.
Apr 16, 2023 at 9:26 AM
Are you referring to the starter not engaging, or the engine won't start? If it is the starter, how did you bypass the neutral safety switch?
